SQL listener & Synthetic monitoring
MikeL
Participant
Would anyone know the proper syntax to use when adding a Synthetic endpoints, then adding both IP & Listener URL both using port 1433, to be monitored.
in our case we'd like to both DNS & IP to be monitored. Here's an example.
2 HTTP requests
1 Request = Get Method & set details to HTTPs: // SQLlistenerURL . domain.ca : 1433 or SQLlistenerURL . domain.ca : 1433
2 Request = Get Method & set IP = 10.10.10.x : 1433
Q1: What are others using for the request HTTP syntax that avoids the Failed requests = "Target URL is invalid", since we tried many, & On-Demand gets a Failure = "MALCORMED_URL_ERROR" (same in Execution details = "healthStatus": "MALFORMED_URL_ERROR"), regardless if its an IP or URL,  it would seems obvious but here we are or we are missing something?
Thx folks for any clarity the community can provide.
5 REPLIES 5
p_devulapalli
Leader
@MikeL Have you considered using a NAM monitor instead ?
Phani Devulapalli
No, we are just early adopters. Could you provide a detailed example of config and expected results for comparison.  Much appreciated.
Mizső
Hi @MikeL,
Here is the documentation link:
Network availability monitoring — Dynatrace Docs
There are some examples:
Synthetic - Demo Live (demo) - Dynatrace
Synthetic - Dynatrace Playground - Dynatrace
I hope it helps.
Best regards,
János
Thx,
What would that actually look like visually once setup?  could you provide a screen shot?
1st & 2nd demo link, 403 You don't have permission to view this page
@MikeL First two links are from demo instance which not everyone might have access to , you should still be able to get to the playground instance and have a look
Playground
Phani Devulapalli
