Troubleshooting
Mareeswaran
Dynatrace Advisor
Dynatrace Advisor
Steps to follow to perform Location dropdown(auto complete Address) with help of JavaScript Event on browser click path synthetic monitor.
  1. Go to the relevant page on Chrome browser
  2. Right click on the element which you want to interact with on the page-> Inspect the element which will open the developer tools
  3. Right click on the element on the Web developer tools - > Copy - > Copy JS path
  4. Paste the JS path on the below element value and add this JavaScript code into the JavaScript Event of your Browser click path monitor which will enter the input value on search field and trigger the dropdown results as shown in the below image
    var element = document.querySelector("#searchboxinput"); //Replace with the element which you want to perform the Location Dropdown
    element.value = 'Waltham';
    var event1 = new Event('input', { bubbles: true });
    event1.simulated = true;
    element.dispatchEvent(event1);
  5. Paste the same JS path on the below element value and add this JavaScript code into the another JavaScript Event of your Browser click path monitor which will select the first dropdown location as shown in the below image
    var evObj = document.createEvent('UIEvents');
    evObj.initUIEvent('keydown', true, true, window, 1);
    evObj.keyCode = 40;
    setTimeout(function() { element.dispatchEvent(evObj); },1000);
    evObj.keyCode = 13;
    setTimeout(function() { element.dispatchEvent(evObj); },2000);
Version history
Last update:
‎12 Apr 2023 02:00 PM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thank you for sharing this
