Troubleshooting
HannahM
Dynatrace Guru
Dynatrace Guru
Summary: HTTP monitors in Dynatrace may return health status codes indicating connectivity or configuration issues. This guide lists common error codes, explains their meaning, and provides steps to restore monitoring accuracy.
Where to find HTTP Monitor Error/ Health Status Codes
HTTP Monitor executions don't always succeed. In addition to the HTTP response codes that a request can return, there are several Dynatrace error codes.
A summary of the HTTP Monitor error codes for a period can be seen in the HTTP Monitor details> Failed Requests card
You can also, find the error code for the most recent failed, successful and on-demand executions in Analyze last failed execution. You can filter the JSON to just show the error. In the JSON the error code is called HealthStatusCode and the error description is HealthStatus.
Error/Health Status Codes and Suggested Actions
Error/
Health Status Code
Error Description/ Health Status
Suggested Actions
0
Healthy
1
SSL Communication error
Check vuc-http-execution.log for more details.
2
DNS query timeout
3
Unknown Host
Check nslookup from the ActiveGate.
4
Unexpected Error
Check vuc-http-execution.log and vuc-http.log for more info
5
Redirects not allowed
6
Invalid Code
Status Code validation failed
Check Monitor> Settings>HTTP Requests> Request> Response Status Code Verification setting
7
Script execution failed
8
Script Fail
12
Http Monitor Execution Timeout
Use Adapt Request Timeout to increase up to 60s. The HTTP Monitor Advanced settings preview can be used to increase the monitor timeout. Ask your CSM or Support for more details.
13
Too many redirects
The maximum number of redirects for synthetic monitors is 10. When a monitor reaches 11 redirects, it fails with this error.
Reach out to your application team to find out why there are so many redirects and reduce them.
15
Connection timeout
Test connection using curl from the ActiveGate
Is a proxy needed?
If a public location, is this endpoint available? Do the public location IP addresses need to be allowlisted by the application?
16
Connection Refused
Does this endpoint require specific headers to be added?
Private location: Test connection using curl from the ActiveGate. Is a proxy needed?
Public location: Is this endpoint available? Do the public location IP addresses need to be allowlisted by the application?
17
Constraint Violated value
Response validation failed.
Check Monitor> Settings>HTTP Requests> Request> Set rule for response validation setting
18
Unknown Method Error
Check vuc-http-execution.log and vuc-http.log for more info.
This occurs when a method is called in the pre-/ post- execution script that the monitor is unaware of. These are usually from third party libraries. For these situations, you must add the code for the function into the script. Like these examples here and here
20
SSL Expiry warning
24
Request Timeout
Test connection using curl from AG
Is a proxy needed?
30
Forbidden URL Error
IP resolves to localhost, which, due to security reasons, is not allowed
Where to find HTTP Monitor Logs
You can either download the support archive or check directly on for HTTP Monitor logs on a Private location. You can find where to check here.
What's next
Open a chat or contact support if
  • you need to check the logs for an HTTP Monitor running on a public location, or
  • the issue is still not resolved after taking the above actions
What to read next:
📖  Synthetic Troubleshooting Map
📖  Synthetic Browser Monitor Error Codes
📖  How can I find which ActiveGate my HTTP Monitor execution ran on?
📖  Create and configure an HTTP monitor
📖  Configure HTTP monitors (classic)
📖  Pre- and post-execution scripts for HTTP monitors (classic)
Version history
Last update:
‎09 Dec 2025 09:59 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thanks for sharing this out @HannahM
ct_27
DynaMight Champion
DynaMight Champion
@HannahM  This is awesome, can this information be posted on the public documentation site? The table you created is so informative. We were just having problem #7 and we found this post while troubleshooting.  So valuable.
nadeem_m
Dynatrace Organizer
Dynatrace Organizer
@HannahM Very Informative!
