noel_david
Dynatrace Organizer
Dynatrace Organizer
Summary
Log ingestion is the process of collecting log data from various sources within an infrastructure. These logs can then be analyzed for many purposes within Dynatrace.
This article provides troubleshooting steps for when logs are not ingested/ visible in Dynatrace.
Troubleshooting
For logs ingested via OneAgent
  • Check if the OneAgent running on the host is the supported version/latest version
  • Check if the Log agent is running on the host. You can do this by going to the host page -> Process analysis section—Filter by technology Dynatrace, and confirm that OneAgent log analytics is running.
  • Check if Log Monitoring is enabled
    • from the Dynatrace WebUI
      • To check if Dynatrace Log Monitoring is enabled globally:
        • Go to "Settings > Monitoring > Monitored technologies".
        • Find "Log Monitoring" in the list of supported technologies, and select "Edit" (pencil icon).
        • Check if the "Monitor Log Monitoring" option is enabled.
      • To check if Dynatrace Log Monitoring is enabled at the host level:
        • Go to "Settings > General ".
        • Find "Log Monitoring" in the list of monitored technologies, and select "Edit" (pencil icon).
        • Check if "Monitor Log Monitoring" on every host option is enabled
    • using the OneAgent CLI tool
      • Use the --get-app-log-content-access parameter to check whether Log Monitoring is enabled:
        Linux:
        ./oneagentctl --get-app-log-content-access​
        Windows:
        .\oneagentctl.exe --get-app-log-content-access​
  • Confirm ingest rules are set up correctly. Log Ingest rules are documented here
    • No ingest rule was created to get the log content.
      These are for the automatically detected logs. To see if the logs are detected by Dynatrace, the easiest way to check is to go to the process group page and check the logs tab.
      • If the logs are not detected, then a custom rule is needed. For a custom rule to work correctly, a log ingestion rule is also required.  (There is now a built-in log ingest rule that you can enable that will ingest all logs from custom log sources.)
    • Multiple matchers of the same type (not to be confused with multiple values for the same matcher).
      The "AND" operator is used between matchers, so usually you want at most one occurrence of a single attribute type in the scope of a single rule.
    • Expecting a partial match in a matcher
      To have a partial match, you need prefix and suffix wildcards.
    • Expecting case-insensitive matching (when it is case sensitive, except log source names on Windows).
    • Check for any typos, including non-visible characters, or non-ANSI Unicode characters.
    • Confirm rule order
      More specific rules should be closer to the top as they're executed top to bottom, and the first catch is decisive.
    • Improper scope
      Rules on more specific levels are evaluated earlier (so they're more important) - host before host group, and host group before tenant
  • Check if any Security rules are violated.
    You can verify this by checking the OneAgent logs.
    Sample log with security warning, which can be verified inside the OneAgent logs.
    [2024-11-28 10:11:29.463 UTC] [/rework/logprocessing/filelogsource.cpp] [info] LGI: / /logs/appl/conc/out/*.txt doesn't meet security rules. (This message was ignored 14 times​
    You can fix this by creating override rules
  • Check if OneAgent has access to the file.
    It might especially happen when a file is on an NFS drive on Linux. Then you need to ensure that the user account OneAgent is running on has access to the file, and also enable NFS drive log detection, Settings > Log Monitoring > Advanced log settings.
    You can run the below command and check if it's accessible.
    sudo -u dtuser ls -l /path/to/logfile
    sudo -u dtuser cat /path/to/logfile
  • Confirm the format is supported.
    Supported encodings include UTF-8 and UTF-16.
  • Confirm the content was not added after the file was ingested.
    No new content is added after the file has been configured to be sent—OneAgent does not send historical data.
  • Confirm that auto-detection limits have not been reached
  • Confirm that the Log Monitoring default limits have not been reached.
  • For managed environments, check the cluster events to see if there are any warnings, as mentioned here
For logs ingested via K8s LogAgent module
  • Verify that the  logmonitoring pod is up and running, using the following command
    kubectl get pods -n dynatrace​
    You should see a pod named "logmonitoring"  running if it's running correctly.
  • Check that you have the prerequisites enabled.
  • Check that you have a matching rule created at the K8 cluster level / Global level.
  • The requirements for autodiscovery and ingestion of Kubernetes logs are the following:
The containerd, CRI-O, or cri-dockerd container runtime is used.
Logs are written to the container's stdout/stderr stream.
See this article for more detailed steps.
For SysLog ingestion via ActiveGate
See Syslog Ingestion via ActiveGate Troubleshooting Guide
For logs ingested via Fluent Bit
See Troubleshooting logs ingested via Fluent Bit
What's next
If this article didn't help, please open a support ticket, mention that this article was used, and provide the following:
Version history
Last update:
‎15 Sep 2025 11:49 AM
Updated by:
Comments
Babar_Qayyum
Hello @noel_david
Thank you for summarizing the troubleshooting points.
What could be the potential issue of no Auto-discovery of Kubernetes/OpenShift logs?
Babar
noel_david
Dynatrace Organizer
Dynatrace Organizer
Hi @Babar_Qayyum ,
In general,
Babar_Qayyum
Hello @noel_david
The log ingested rule is applied on the namespaces level, and also these are important processes.
Babar
noel_david
Dynatrace Organizer
Dynatrace Organizer
Hi @Babar_Qayyum ,
Please create a ticket, with all details.
Babar_Qayyum
Hello @noel_david
I just wanted to update you that log monitoring was not enabled on the global level.
Babar
erh_inetum
Champion
Hi @noel_david ,
Thanks a lot for your great post.
I think we can add another use case in "Improper ingest rules" point:
In this case the log will not visible in Dynatrace either.
Elena.
noel_david
Dynatrace Organizer
Dynatrace Organizer
Hi @erh_inetum , Thank you .
Can you please share an example here, if possible,
erh_inetum
Champion
Hi @noel_david ,
Here an example: for this kind of rules
we have seen that if the process group doesn´t have deployed services
the log isn´t captured. But it is in case the process group has deployed services.
Please, let me know in case my explanation is not clear and it try to explain it better again.
Thanks you so much.
Elena.
noel_david
Dynatrace Organizer
Dynatrace Organizer
Hi @erh_inetum ,
I tried to reproduce the issue but was unsuccessful; if you can share a sample, it will be unique. Can you share me if you have one? A support ticket will be perfect.
erh_inetum
Champion
Hi @noel_david ,
The screenshots that I put in my comment below are the issue we had and how to reproduce it.
We haven't opened a ticket because we configures the rule for an specific host and we got the log.
Let me know if this information os enough.
Thanks so much.
Elena
StrangerThing
DynaMight Mentor
DynaMight Mentor
For this point:
There is now a built-in log ingest rule that you can enable that will ingest all logs from custom log sources. Just enable that rule and you don't have to worry about making multiple rules.
noel_david
Dynatrace Organizer
Dynatrace Organizer
Hi @StrangerThing , Thank you.
@erh_inetum , Thank i'll have a  look
