Troubleshooting
HannahM
Dynatrace Guru
Dynatrace Guru
Summary
If you're using a Private Synthetic location, at some point, you'll want to check the logs for more information about what you're troubleshooting. This article aims to give you some direction on which logs to look at.
Default locations for logs
You can also download the Support Archive from the WebUI by running the Dynatrace ActiveGate Diagnostics. This will only give you up to 7 days of Synthetic logs, so if you need a log that was last written before that, you'll need to find the file directly.
Helpful files and folders
Synthetic installation log
  • Linux: /var/log/dynatrace/synthetic/dynatracesynthetic-install_<datetimeOfInstall>.log
    If this file does not exist, you can check
     /tmp/ for any dynatracesynthetic-install <datetimeOfInstall>.log files.
  • Windows: C:\ProgramData\dynatrace\autoupdater\log\Synthetic_<version>.log
The Synthetic installation log details the installation of the Synthetic module. This is the place to check if you see the Synthetic module update has failed or been skipped. It also provides information on the Chromium autoupdate.
It should be read alongside the Gateway installation log, which is located at:
  • Linux: /var/log/dynatrace/gateway/dynatracegateway-install_<datetime>.log
  • Windows: C:\ProgramData\dynatrace\gateway\log\dynatrace_ag_install_<datetime>.log
Synthetic Module start-up log (VUC Wrapper Launcher)
  • Linux: /var/log/dynatrace/synthetic/VucwrapperLauncher_<datetimeOfLaunch>.log
  • Windows: C:\ProgramData\dynatrace\synthetic\log\VucwrapperLauncher_<datetimeOfLaunch>.log
This log is written to when the VUC service is starting up and contains things like the process id and port being used. It often has helpful messages when the VUC service is failing during startup or has stopped unexpectedly.
Synthetic Module (VUC) Logs
  • Windows: C:\ProgramData\dynatrace\synthetic\log\synthetic
vuc.log
This file captures the core VUC functionality logs. It includes logs related to the VUC's connection with the ActiveGate (e.g., localhost:9999/...), as well as startup/shutdown activities, common services, and the loading of configuration properties.
vuc-browser.log
This log provides high-level Browser Monitor module logging and covers the execution and lifecycle of visits. It contains information on screenshot storage, WebSocket issues, and other problems encountered during the start up of the Browser module and execution of Browser monitors. The outcome of the diagnostics test on start up can be found in this log by searching for DIAGNOSTICS TEST
vuc-browser.debug.log
This log provides the debug level detail from the browser monitor diagnostics tests run when the Synthetic module is starting up.
vuc-dns-execution.log
This log file details monitor execution events
vuc-http.log
This provides high-level HTTP Module logging, including monitor start and stop times, script loading, and detailed error information, such as "Unknown Method Error" and "Unexpected Error". The outcome of the diagnostics test on start up can be found in this log by searching for DIAGNOSTICS TEST
vuc-http-custom.log
Entries in this log are generated from JavaScript execution. You may find log messages created by the API calls api.info(message), api.warn(message), and api.error(message).
vuc-http-execution.log
This log file details monitor execution events, including script execution failures, SSL communication errors, DNS query timeouts, and other unexpected errors.
vuc-http.debug.log
This log provides the debug level detail from the http monitor diagnostics tests run when the Synthetic module is starting up.
vuc-icmp-execution.log
vuc-multi.log
This log provides high-level NAM, Multi-protocol, module logging and covers the execution and lifecycle of visits
vuc-multi.debug.log
This log provides the debug level detail from the NAM diagnostics tests run when the Synthetic module is starting up.
vuc-tcp-execution.log
vuc-status.log
This log offers a summary of each VUC startup, including configuration settings and version information.
Synthetic Player (VUP) Logs
Location for individual Browser Monitor execution logs:
  • Linux: /var/tmp/dynatrace/synthetic/logs
  • Windows: C:\ProgramData\dynatrace\synthetic\temp\synthetic\logs
For archived logs:
  • Linux: /var/tmp/dynatrace/synthetic/archivedLogs
  • Windows: C:\ProgramData\dynatrace\synthetic\temp\synthetic\archivedLogs
Log File Format: <tenant_id>-<test_def_id>-<visit_id>-<timestamp>-ch.log
Execution logs from logs folder are archived hourly into 1 hour zip files in the archivedLogs folder.
These logs provide details on:
  • WebSocket connections to the VUC.
  • VUP, browser, and JavaScript Agent versions.
  • Execution error codes and messages.
  • Custom log entries created by API calls (e.g., api.info).
What's Next
You can find troubleshooting tips for Synthetic in the Synthetic Troubleshooting Map
Version history
Last update:
‎20 Oct 2025 04:26 PM
Updated by:
Comments
AurelienGravier
DynaMight Champion
DynaMight Champion
Hello @HannahM
I would like to leverage the execution logs of the synthetic tests to perform statistics based on these custom events (api.info) for each synthetic test.
I can detect my custom events by looking at the Synthetic Player logs, but there are no attributes to identify the synthetic entity related synthetic testID.
For example, below is a log entry:
How can I map the testID with the dt.entity.synthetic_test related to it ?
Thank you for your help.
