20 Mar 2024 02:12 PM - edited 20 Oct 2025 04:26 PM
If you're using a Private Synthetic location, at some point, you'll want to check the logs for more information about what you're troubleshooting. This article aims to give you some direction on which logs to look at.
You can also download the Support Archive from the WebUI by running the Dynatrace ActiveGate Diagnostics. This will only give you up to 7 days of Synthetic logs, so if you need a log that was last written before that, you'll need to find the file directly.
The Synthetic installation log details the installation of the Synthetic module. This is the place to check if you see the Synthetic module update has failed or been skipped. It also provides information on the Chromium autoupdate.
It should be read alongside the Gateway installation log, which is located at:
This log is written to when the VUC service is starting up and contains things like the process id and port being used. It often has helpful messages when the VUC service is failing during startup or has stopped unexpectedly.
This file captures the core VUC functionality logs. It includes logs related to the VUC's connection with the ActiveGate (e.g., localhost:9999/...), as well as startup/shutdown activities, common services, and the loading of configuration properties.
This log provides high-level Browser Monitor module logging and covers the execution and lifecycle of visits. It contains information on screenshot storage, WebSocket issues, and other problems encountered during the start up of the Browser module and execution of Browser monitors. The outcome of the diagnostics test on start up can be found in this log by searching for DIAGNOSTICS TEST
This log provides the debug level detail from the browser monitor diagnostics tests run when the Synthetic module is starting up.
This log file details monitor execution events
This provides high-level HTTP Module logging, including monitor start and stop times, script loading, and detailed error information, such as "Unknown Method Error" and "Unexpected Error". The outcome of the diagnostics test on start up can be found in this log by searching for DIAGNOSTICS TEST
Entries in this log are generated from JavaScript execution. You may find log messages created by the API calls api.info(message), api.warn(message), and api.error(message).
This log file details monitor execution events, including script execution failures, SSL communication errors, DNS query timeouts, and other unexpected errors.
This log provides the debug level detail from the http monitor diagnostics tests run when the Synthetic module is starting up.
This log provides high-level NAM, Multi-protocol, module logging and covers the execution and lifecycle of visits
This log provides the debug level detail from the NAM diagnostics tests run when the Synthetic module is starting up.
This log offers a summary of each VUC startup, including configuration settings and version information.
Location for individual Browser Monitor execution logs:
For archived logs:
Log File Format: <tenant_id>-<test_def_id>-<visit_id>-<timestamp>-ch.log
Execution logs from logs folder are archived hourly into 1 hour zip files in the archivedLogs folder.
These logs provide details on:
You can find troubleshooting tips for Synthetic in the Synthetic Troubleshooting Map
Hello @HannahM
I would like to leverage the execution logs of the synthetic tests to perform statistics based on these custom events (api.info) for each synthetic test.
I can detect my custom events by looking at the Synthetic Player logs, but there are no attributes to identify the synthetic entity related synthetic testID.
For example, below is a log entry:
How can I map the testID with the dt.entity.synthetic_test related to it ?
Thank you for your help.
Hey Aurelian,
I can't remember how it's calculated right now, but you can find it in the vuc-browser.log by searching for the line where the test is fetched. This shows both the dt.entity.synthetic_test and the test definition ID (TESTID in the log above).
2025-12-29T10:50:50.537Z INFO [v=35146621929205573] [BM-PeriodicVisitFetcher-1] PeriodicVisitFetcher: Fetched to run BrowserVisit[35146621929205573/SYNTHETIC_TEST-A7D5C33596196D80/-6352957064417284736/-6352957064417284736], execType: ON_DEMAND, procMode: PROCESSING_STANDARD, weight: 1, run: 1/1, scriptLastModified: 2025-12-29T10:43:32.670Z, bf: BeaconForwarder{endpoint="https://localhost:9999/beacon/kqu36999", tenant="kqu36999", isSaaS=true}, meta: []]
In this example, SYNTHETIC_TEST-A7D5C33596196D80 is the dt.entity.synthetic_test and -6352957064417284736 is the TESTID.
If you want to find the id the other way, so from a monitor, find it's test definition id in the WebUI, you can check a link for one of the screenshots. For this monitor execution it's https://ruxit-synth-screencap.s3.amazonaws.com/prod-us-east-6-virginia/kqu36999/-6352957064417284736/35146621929205573/Action_1_regular.jpeg
I tried finding it in GRAIL but didn't have any luck. It will be in the browser_monitor_step_execution event, when that goes live next Quarter, but even then it was as part of the screenshot.thumbnail_uri rather than on it's own.
@AurelienGravier apologies, I was obviously having a senior moment. The SYNTHETIC_TEST id and the TESTID from the logs are the HEX/ decimal versions of each other.
So for the example above, A7D5C33596196D80 (in hex) = -6352957064417284736 (in decimal)
