Troubleshooting
yngwie_lucero
Dynatrace Advisor
Dynatrace Advisor
In most cases for iOS, the crashes and session replay are not captured because of the debugger attached to the build. In this case, the debugger hooks and catches the crashes causing all crash handlers to not work properly.
If you have the debug logging enabled for iOS you should be able to see a warning from the logs:
If you see this message then you need to detach the debugger. By following the steps below:
1. In Xcode, go to "Edit Scheme" under your project target.
2. Uncheck "Debug executable"
3. Clean and build the application before running in simulator/device.
You can also detach the debugger on a per-run basis. This way you do not need to remove it from the scheme and just detach it for the current run.
Version history
Last update:
‎19 Dec 2023 04:06 PM
Updated by:
Comments
ChadTurner
Legend
Thank you for Sharing this!
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
